DesignSeries02501.pngJoining walls
Tool
Workspace: Tool set
Wall Join
Architect and Spotlight: Building Shell
Landmark: Building Shell and Site Planning
The Wall Join tool joins straight or curved wall segments and their components. There are three modes for joining walls and two end cap modes.
Mode
Description
T Join
Lengthens or shortens one wall segment until it intersects with the second wall segment selected; creates Y joins by joining the first selected wall to two sections of an existing L join
L Join
Joins the closest ends of two walls to create a corner
X Join
Joins two wall segments at the point where they intersect
Uncapped Join
Applies an uncapped join to wall join operations
Capped Join
Applies a capped join to wall join operations
To temporarily activate this tool, right-click on a wall, and select Join from the context menu. The tool defaults to the mode used previously with the tool.
Reshaping walls
Removing wall breaks
T wall joins
Y wall joins
L wall joins
X wall joins
Joining walls with the Fillet tool
Wall Insertion mode
Unión automática de paredes
